Maybe this is a problem that I'm the only person in the world has seen but with millions of SIEG lathes out there, maybe someone has seen it.
My big lathe is a Sieg SC4 bought as the Little Machine Shop 3540.
I've been having issues with a ground fault interrupter in my shop popping for a while that are definitely not related to the lathe. The lathe will be off and the GFI will turn off power. The majority of that went away when the electric utility replaced a transformer, but it would still pop open every few weeks or go a couple of months.
Last week, I replaced the GFI outlet with a brand new one and then the weirdness started.
Saturday, I turned on the lathe and was turning a piece at minimum speed (100 RPM). I started running up the speed (RPMs) and popped the GFI. I recreated that test three more times and every time the ground fault cut the power when I got above 150 RPMs. I've run the lathe faster than that many times, on the GFI outlet that I replaced because I thought it might be bad.
As a test, I put the possibly bad GFI back in the wall and put the new one aside. Now I can run higher RPMs like I always did before.
So I got a third GFI outlet (True Value hardware loves me). Sure as can be, when I cranked up RPMs on the second NEW outlet, it also popped the GFI.
Now I have two different, NEW, GFIs, that do the same thing. I have one old GFI which doesn't pop at lathe settings that make the other two pop. It's not really easy to make sense of that. It seems to me that the lathe speed controller is probably doing something wrong during the transients while speeding up.
Anybody seen something like this?
More importantly, how do I fix this?
