This week I had a visit from an 87 year old gentleman who has a 98 year old, 5 HP Leister gasoline engine. This engine had a combination fuel and oil piston style pump which has two 0.640 diameter brass pistons sliding in brass cylinders and driven by cams on the engine. Each cylinder has a reduced diameter section which he informs me his father used to pack with butchers cord soaked in grease to provide a good seal to make the pump work well. He said that of course this didn't last very long, and he wanted to know if I could suggest an alternative solution. Since the pistons are two peice construction, I can machine an aluminum ring to fill the gap which they originally packed with string and grease and machine an o-ring groove in the aluminum. I know that o-rings are made for both static and dynamic applications, and this seems to me to be a reasonable solution. I just don't know how well a standard Buna N type o-ring stands up to gasoline. Any suggestions?---Brian
