Leaky joints
Used that type on a old Atlas mill and did not have trouble with leaks.
Don't use coolent in the home shop anymore. No need to run cutters at high speed or make heavy cut and just found it more of a mess and cleanup problem then it was worth.
I use LocLine hoses on my CNC mills and they don't leak at all. Something is wrong there.
Did you get the tool for assembling lock line together. If not assembled correctly you could have the problems you are encountering.
If the garbage man has not picked up yet send it to the folks that made it .
Lockwood Products
5615 Willow Lane
Lake Oswego, OR 97035
Ask them why it leaks may be a bad batch.
