A recent thread- and several in the past- have discussed the use of the VFD on the lathe. There are good reasons to use one- it's the cheapest, and often only, way to run three phase motors in the home shop.
Beyond that, though, there seems to be a tacit view that infinitely variable speed is in and of itself a good thing, worth having on all machines. I wonder if that's so, particularly for the modern gearhead lathe. A well designed lathe comes with geometrically spaced speeds on the pulley or gearhead. Those speeds were carefully chosen to optimize performance and tuned over decades of experience. Most of us here, I suspect, cut aluminum, steel, or brass in sizes ranging from a quarter inch or so up to about six to ten inches. Available speeds are a bit slow for small diameters at least on my 13" Standard Modern, but still usable, and just fine for work in the 1-10 inch range with HSS bits and in most cases carbide. Tooling, technique, and skill affect my results; within reasonable limits, sfm does not.
So, a question for the experienced hands here. Is it really worth the effort to convert a well-designed lathe with geometric speeds to a VFD, absent any other reason to do so than to get infinitely variable speed? What objective evidence exists -if any- that this is worthwhile?
I understand the theoretical argument that one can run at exactly the recommended sfm, but in practice one is rarely at that speed even with a VFD- and in any case, the recommended sfm must be a range, not a unique single number. And, no doubt, if one is building or converting to direct drivewith a couple of speed ranges, VFD is the technology to use. The question is whether there's practical value in changing a well designed, fully functional lathe to gain nothing but variable speed.
My vote is "no", as evidenced by the simple fact that this remains a project I've never gotten around to doing, despite thinking about it with some regularity.
The discussion should be interesting.
