larryg
So with the V block work done it on to other steps. For me it was figuring out how to hold the rod. Digging in the scrap box I found this black piece ( fixture);
It was machined nice, square, and parallel. The rod itself has an offset of .1625" from the side of the big end and the small end. So I machined the end of another piece of scrap to .1625" as a spacer for the big enc. Centered on one end and .650" up from the end of the fixture I drilled a tight clearance hole for a 1/4" shcs and counter bored the back side. I also drilled and tapped a couple of 1/4-20 holes to align with the angle fixture I have to hold it vertical.
So with the fixture bolted to the mill I aligned it to the travel,
Once aligned I located the the rod end and drilled and tapped the for the rod bolts.
lg
no neat sig line
lg
no neat sig line
