Hi Gerritt & Norm,
It was a fun project that has given me a great tool at the end!
Norm,
The digital angle gauge is a neat tool. Makes it easy to set things like the head in the mill to be consistent angle between parts...even though it's not required here! As to the QCTH yes well I love mine! It would have been far cheeper to make a block to fit an existing holder....it cost the equivalent of 3 off the shelf holders for the water cutting! Oh I also made a boring bar holder one for a 20mm boring bar that I have been using rather dodgy for a number of years, it'll get more use now it's a lot safer to use!
Make one Norm you will find that knurling becomes easy! My procedure is start the lathe, move the knurls up so both are rotating, lightly tighten the knob just enuff to hold the tool holder, move the cross slide back towards the tailstock, the knurls will stop, put on your cut, on the 1.0 mm knurl I've been using 0.5mm engage the power feed & watch the knurls form! Apply LOADS of cutting fluid. One cut, perfect knurl! Well to me they look pretty good. Just did another yesterday on Barry's suggestion I step up the speed from 60 to 120 rpm & a feed of 0.044 mm/rev worked great.
There was a couple of comments on Barry's post about these not cutting, on this mine sure leaves a a lot of cuttings for a system that doesn't cut!
My bandsaw has had a few....understatement......mods done to it about 12 months ago here's a link if you are interested in another project.......
http://www.modelenginemaker.com/index.php/topic,6363.0.html
Barry,
I had a light bulb moment yesterday when I had a sort up of the lathe tools. The tool heads don't need individual threaded rods! It dawned on me that the knob fitted securely to one rod could be screwed into the head required, for me it will make storage easier!
Alan,
Barry's post on knurling has a couple of videos....think the title is "help on knurling "
Cheers Kerrin
