Ive been working on the base assembly for this engine. I wasnt going to post until I had the assembly completed but that would make for a fairly large post so Ill break it into two parts.
This assembly consists of a base, four support columns, column finials, a table, a pair of bearing blocks with bushings and a pair of oil cups.
I started with the table. This is the upper deck of the engine upon which the cylinder block sits. This engine is also referred to as a Table engine for this reason. The table is drilled for mounting the cylinder block, the four support columns, tapped for mounting the valve gear and it is also milled to produce two slots through which the connecting rod assembly travels. This is one of those times when a picture is really worth a 1000 words so:
I counterbored the holes for the column connections by about 0.020 and the ends of the columns will have a register to fit into the recess. The same connection will be made from column to base. I dont like straight butt joints where theres going to be some side-to-side stresses.
I had a piece of 5/8 thick aluminum stock that was 8 wide and I used this for the base. Clearance holes for ¼ screws were drilled in the base for the support columns and the bearing blocks. I used an F drill for this purpose.
I used a 45º bevel cutter to form a bevel around the top of the base to finish off its appearance.
Next I worked on the bearing blocks. They have a nice scalloped look. I spent some time to layout a plan to avoid a lot of extra milling. The plans called for aluminum here but I wanted to make them in steel. The starting point for these was a ¾ x 3 bar of hot rolled steel. While milling a pair of blank blocks from this stock it occurred to me why castings were invented. Im going to be cutting away quite a bit of metal to get the finished product.
Well heres a lazy days work in this picture. Two blank bearing blocks are sitting on a piece of the parent stock. In the middle is a piece of steel scrap that I used to practice making the scalloped sides of the blocks. Luckily, cutting metal relaxes me.
Im not sure that the sequence of machining operations is all that important but at this point I have two fairly accurately milled rectangles of steel. The base mounting holes, the bearing hole, and the bearing cap mounting holes are the critical dimensions so I decided to do those first since I have true edges to work from. After these are machined its really just a matter of carving away a lot of metal to get the sculpted appearance.
The bottoms of the blocks were drilled/tapped for mounting to the base. The tops were drilled/tapped for the bearing caps. Here I diverged from the plans. The plans show the bearing block and the cap made as separate pieces. I used an approach that is common for casting models. That is, the bearing block and cap are made from a single piece of material. The cap mounting screw holes are drilled and tapped. The cap is cut off from the base, then the cap is screwed to the block and finally the hole for the bearing is drilled and bored.
Two holes are bored in the bearing block. One for the crankshaft bushing, the other is an architectural detail. Bearing blocks that have been drilled and bored but not fully profiled are shown here:
Now I needed to profile or scallop the edges of the blocks. This requires a combination of sawing, milling and drilling. I really prefer to saw excess material rather than mill it away for a number of reasons. But I once had a bad experience with the bandsaw blade becoming dull in the middle of a cut and wandering sharply into the workpiece. So I decided to mill away the excess on the first block. After many passes with the end mill I was convinced to do the second one using the bandsaw to remove most of the excess. Having finished the first block, I traced its outline on the second block and carefully watched the bandsaw blades progress. After sawing the edge was made true using an end mill to the final dimension.
Scalloping the sides was accomplished with a ¾ centercutting end mill. I drilled this scallop into the workpiece by feeding it under the end mill in increments until I reached the desired end point.
Now I used either an end mill or the bandsaw to get rid of excess material. When I used the bandsaw, I made the side true with an end mill before cutting the other side.
I breathed a major sigh of relief when the bearing blocks were finished. The machining operations werent all that challenging but there was a lot of milling, deburring, sawing, deburring, drilling, deburring. I learned some time ago that you can skip the deburring steps in between. You are rewarded for doing this with some fine paperweights.
Ive mounted the bearing blocks on the base here.
They seem like they came out OK but the real test is their function. So off to the shop to make a pair of bronze bushings. I had an piece of oilite bronze I picked up some years ago that was made for this project. The bushings were turned to fit each bearing block for a press fit. They turned out to be only a 0.001 apart in diameter. Since I can loosen the bearing caps pressing them in wasnt required. With the caps tightened I dont think the bushings will wander.
One of the real benefits of working at this hobby over time is that you accumulate a collection of dowels, engine parts, screws, bolts etc. of a variety of sizes. Need a dowel of diameter 0.812? Check the parts bin and youre bound to come up close.
Rummaging around I located a crankshaft with the proper diameter (5/8) and a spare flywheel to test out my alignment of these bearing blocks on the base. The arrangement is sort of an assault on the senses but I discovered that the flywheel turns effortlessly in the bearings. The actual crankshaft for this engine needs to be about 2 longer and the flywheel for this engine will be spoked, made from a casting.
So far each assembly functions smoothly on its own. Eventually all the assemblies will be connected and will need to work as designed. That test, the final exam, is still far off.
Now Im ready to work on the next phase of this base assembly, the support columns. When I finish those, Ill make the piston and piston rod. Then I can test the base, cylinder, connecting rod and crosshead assemblies all connected together, the mid-term exam.
Phil
