Over the last few weeks, I have designed and been making a very hi speed drilling unit. I need to drill holes of 0.006" diameter or less for making gas jets for miniature bunsen burners to use with flame licker and sterling engines.
http://www.jerry-howell.com/Propane.html
This is as far I have got, maybe 3 or 4 hours work to completion. It will run at about 50K RPM.
It is made out of a donated DTI stand and a couple of cheapo bits from China, plus of course some bits 'n bobs from the scrap box. It will run from the air system in my shop.
About a year ago I mentioned to a friend that I was on the lookout for a cheap hi speed PCB drill.
Last night, he turned up and gave me this, FOC.
A purpose made Meddings hi speed drill. This one is only equipped with the cones to go up to 6K RPM, but it is a dead easy job to make new flat belt cones (they can be bought, but are rather expensive) to get way past that figure, and the blue blank you see, when turned up, should get me up to around 12K, once I get some larger ali blanks, I expect to be up around the 20K mark.
I had to try it out, and I'm sorry for the fuzzy pic, the termite holes are 0.020", shown against a 3mm cap screw.
No problems drilling these at 4.5K RPM.
Blogs
Blogs
