Insert tooling, for positive ground inserts. (222 if I recall their size correctly - the 'commonest' variety work well.)
Materials: 7/16ths drill rod, 7/16ths cold drawn W1, 1/4 inch brass rod for shims, 8-32 (?) socket head screws, heat source, quenchant.
Oh, and a lathe. You make these ON the lathe. I did not use a milling machine. More, I used a 7X10!
1) Using the lathe and an arbor-mounted slitting saw, cut off several suitable lengths of that W1 stuff. Debur the pieces with a fine file.
2) Using the aforementioned lathe and slitting saw, cut your shanks such that they're fitting your inserts. I used the smallest common ones
I could find, those having 1/4 inch included circle, triangular, positive ground for three cutting points. I made a right, a left, and a center. Debur
the pieces with your file(s).
3) using a 1/4 inch carbide end-mill, cut out the sections where the inserts will go. Note that you will need to go VERY slow, both as to speed
and feed. Use a fresh end-mill, or if possible, use a slightly undersize one for roughing and finish with the fresh one. I ended up needing a THIN
brass shim under mine due to clean-up aspects. Again, debur with a file or three. I'd recommend using a fine three-square one for this job.
4) chuck up the drill rod, face the end. Now, using a brass block or stack of shims between one of the three jaws of the chuck, chuck the drill rod off-center. You're going to make the clamp now.
A) bore a place for your tailstock with a center-drill.
B) turn the 'shank' of the thing. This needs to be .250 long, and .250 diameter. ( I think. I've got the lathe in pieces right now and the whole
area's an unholy mess. It will remain that way for some days yet, due to illness.)
C) undercut an area around the shank on the underside of the clamp's 'head'. This gives a small 'bump' for the insert, which you'll cushion with a brass shim.
D) drill a passage for an eight-32 socket-head cap-screw.
E) part off the piece. Chamfer and debur. Set aside.
5) return to your shanks. Drill, tap, and then ream the appropriate place for the clamp to go in. See drawing. Debur, test-fit parts with insert.
6) make the shims such that the clamp holds the insert in place.
7) heat-treat shank and clamp - use oil for both. W-1, least in small sizes, does get fairly hard. Draw shank back to a medium to dark straw, the clamp to a purplish blue.
See drawing (I know, not too good. I've got a sinus infection, and a headache that's bad enough to make me wonder about migraines.)
dennis
