Bret,
There are lots of bling opportunities even if the engine is kept the same size and none of the operational dimensions are changed. I too like the adjustable rollers as shown on the first link (Cedges). To do them on Elemer's size engine would require that the cam ring be made larger to allow room for the adjustable portion and the piston rod also increased in length. One minor problem is that the piston rod would need to be threaded right hand on one end and left handed on the other so it would work like a turnbuckle. Otherwise your adjustment would be in 1/2 turn increments of the thread pitch used. Also, on Elmer's version, the roller forks guide the piston to keep the rollers centered on the ring, so the forks can not be rotated. This could be changed, but then there is the additional requirement to keep the cylinder centered on the cam ring. All this is possible, but each change means another place that error can creep into the build. If you make many functional changes, then you are starting over with a new design. I don't think that is a good idea for a team build. Certainly minor changes and bling should be a given however.
Bret, are you doing your version of Chuck's Horizontal in CAD so that it might be considered for a team build later. You are a little ahead of me in your version, but I am catching up - maybe. The more I build and look at it the more tinkering I think will be required to make it run well over a wide variety of input pressures. This might not make it a good team project. Still it is a fun project. I am documenting my changes in CAD, but only as working files and not finished drawings.
Gail in NM,USA
