- Jul 16, 2007
- 3,059
- 1,195
In this hobby the biggest use for O rings I suspect is for piston rings. While one can argue the success of this type of usage the design intent of O rings isn't made for this type of application. To generally be affective O rings need some type of compression to create the seal between the shaft or surface they are being used for. For reciprocating or rotating shafts the surface finish must be smooth enough to not abrade the O ring yet not so slick as to cause the oil to wick past the interface. In the case of using O rings for valve seals I'm sure it would work but with ever so slight variables in O ring sizing (past discussions on using O rings for piston rings) trying to get just the right fit in such a small diameter would be painstaking.
As far as my engine smoking from top end leakage it has to be realized that the area under the rocker cover is bathed in oil as is it's full sized counterpart and even with tight tolerances between the valve and guide there is still that small clearance for the oil to be drawn past, especially when there is a vacuum applied.
It's nice to have conversations like this because with enough responses you get to find out what successes, or failures, others have had with certain components.
gbritnell
gbritnell
