- Aug 25, 2007
- 3,890
- 715
Started getting a slow drip off the hot-water shut-off valve under the sink in the guest bathroom a couple of days ago. So, today, after shutting off the water to the house, I got some tools and started work on it. Of course it took 5 more trips to the shop because I seem to have to sneak up on getting the right tools.
I got it apart and discovered it was just a compression fitting so that should be easy to fix. But, not so fast, the builder put the fitting on so tight, the sleeve swaged down the copper pipe. Well, fortunately, the pipe had lots of extra length to it. No room for a proper pipe cutting tool, so I grabbed my dremel tool with an abrasive cutoff blade and began cutting it off. Five blades and lots of filing later I had it dressed back to clean, round pipe.
Then off to home depot to get some new brass sleeves. I decided to go ahead and get a whole new valve and some extra sleeves. Already long story short, I got the new fitting on, everything hooked back up and (so far) it's not leaking.
Nothing with plumbing is ever easy! Luckily, this time, it was fairly cheap!
Chuck
Chuck
