^^ That's my tricky title for yet another feeds & speeds question!
I've never been big on mathematically-derived feeds/speeds for manual work. I usually speed things up until I can physically feel a bit of laboring going on, or the cut doesn't work out right, but under NC, there is no feel, and I must program in the correct parameters.
What I am doing is leaning towards the traditional definition of HSM... high spindle speeds and feeds, with a "bite" appropriate for the spindle wattage and the cutters in use. I want to mill several small but complex 3D parts from 7075 aluminum, using both 1/8" and 1/4" carbide mills. My spindle is only 600 watts, but I can dial upwards of 50,000 RPM.
Can anyone point to a good online speed/feed calculator, or suggest basic parameters for light but fast cuts in aluminum? As always, thanks.
