- May 27, 2010
- 2,999
- 1,171
Gear Case.
Profiling the Gear Case required angle plate bought three years ago from the engineering hardware streets in HongKong.
With item secured the two flats for the cam tappet bushings skimmed to print dimensions. Job done with no goofs.
Milling the exterior profile was made tedious using a mini mill. Vertical feed was short by 3 mm. Had to lower mill head to finish cut. Job done again with no goofs. Both cuts too 3 1/2 hours. Gear Case Assembly will take the rest of the week.
