- Jun 2, 2017
- 63
- 14
Before I spin the crank around to set the valve clearance, I think I should install the distributor cap while the #1 piston is at TDC (I know my cylinder numbers are labeled wrong, but I had other parts/pics referenced to it before I realized it, so kept it to avoid confusion)
My question is, how do I set the distributor up? There is a gap between the outer rivets and contact arm, so with cap installed I can't check for continuity with mutimeter.
What is the step by step process to set up a distributor? (magnet disk w/hall sensor ( what leads on hall sensor I connect multimeter to test) and the cap?
Thanks
Thanks
