PaulMakesThings
New Member
- Jul 26, 2014
- 2
- 1
[Edit, never mind, stupid question. I should have realized they make inside calipers that small, can't see a way to delete the post]
I need to measure the bottom of a very slightly tapered hole to make a part seal into it. Taper is exaggerated by a lot in my drawing.
The top of the hole is .525. The depth is 2.03 measured to the edge of the bottom. My digital calipers don't have jaws long or narrow enough to get to the bottom of this. My angle gauge is too wide to fit in the hole. The bottom has a 0.25" hole in it and may be funnel shaped.
So I'm trying to figure out a good way to measure the diameter of the hole bottom (labeled D here). It would also be good to get the angle of the sink at the bottom. The crucial thing is that this hole has a clamping element in the side. It's shaped like the curve of the hole, and it can only move inward about 0.010", ideally it shouldn't have to push the plug off center very far. A hole goes through the middle of the plug I'm making, so if the fat part of the plug is too lose it will bend the neck of the tube. I realize I'll need to leave a little slack in the small part of the plug so the clamping doesn't bend it. But without that bottom diameter or the angle of the sides I can't even make it close.
Any ideas? This seems like something machinists would have a trick for.
Thank you!
Thank you!
