Hi guys,
I was cutting some steel for the first time on my mini mill. Oh, I have trimmed some t-nuts before, but other than that I have only milled aluminum.
So anyway, I was cutting cold roll steel, 5/8" thick and I needed to mill down 1/4" of it for 6" long by 1.25" wide.
I initially used a 1/4" roughing mill (first time use) and only made a few light passes, working my way deeper and when I was at .030" the cutter snapped in half. So to finish the job and because I was mad I stuffed the largest cutter that will fit into my holder, a 5/8" 4-flute and finished the job. I was using cutting oil and the chips were flying off smoking hot. It looked like a WWII navy air combat movie! ;D
I just kept brushing the cutter with oil because I did not want to burn it out. But when I was finished I had a mountain of soggy, oil soaked swarf. I have never had such a mess before.
Did I over do it? Do I need to constantly be brushing the cutter with oil when I am milling steel? IIRC my deepest cut was .030" but I could definitely feel the pull when turning the wheel on the table.
Thanks!
Thanks!
