Hi,
A rough estimate of boiler size can be gained as below:
Estimate steam consumption:
Ideally this can come from measuring the area of the indicator diagram of course, you will not have this, so take the worst case of swept volume of the cylinder multiplied by the pressure (i.e. assume no cut-off). This will give steam consumption per power stroke.
Multiply the steam consumption per power stroke by the number of cylinders, the RPM and a factor of two if it is double acting to give steam consumption in terms of volume per minute. Knowing the pressure that you want to work at, use steam tables to convert this volume to the equivalent mass of steam per minute.
You now have an estimate of the amount (mass) of water you must boil per minute. The estimate ignores condensation in the cylinders, the effect of dead space etc. and can be under estimating the real steam consumption by up to 50% - so double this estimate to be on the safe side.
Now you have to evaporate the calculated mass of water estimates for the steaming rates (in cubic inches per minute per 100 sq inches of heated surface) for some of the more common boiler configurations are:
2.5 3.5 dia. Simple spirit fired pot boiler = 1.0
3 inch dia. centre flue spirit fired = 1.25
3 inch dia. centre flue gas fired= 2.0
3 inch dia. Cross tube gas fired = 2.5 3.0
2in x 6in horizontal with circulating tubes, gas fired = 3.0 3.5
(The above figures are from The Model Engineers Handbook by Tubal Cain)
Ian.
