Hot-Bulb Semi-Diesel Plans Wanted
Steamchick
Re gears
What I thought would be a simple task has proven to be quite difficult re suppliers of suitable gears. I haven't been able to track down the US supplier but will keep looking as I will have it some where. The price delivered to Australia was $96 Aust and that was two and a half years ago. The postage represented about a third of the cost but that is life.
The Chinese supplier seems to have disappeared off Ebay however, I found another source - see attachments. I found these on Ebay out of HK so I hope it helps.
Bruce W-S
Hi Bruce, I like your test engine. Very conventional arrangement. I wonder - did you buy your gears for the valve drive/cam shaft drive? I have been looking and can't find any commercial gears at 2:1 ratio, and do not have the tools and ability to cut them. Ta,
K
I thimk you have the ability, just not the tools
I have spent some time looking up info re hot bulb engines and there is not much about. There are a couple of links which you may find of interest:
Hot Bulb and Glow Plug Difference | Model Engineer
This article gives a good run down on the operation of the hot bulb engine.
The next link has photos of some models that have been built
Alyn Foundry Home Page
The next link is to a book primarily about the design of early diesels however it may also go through the theory of hot bulb as they were the for runner of the compression engine (diesel).
http://library.um.edu.mo/ebooks/b31944164.pdf
From my reading on the subject, the principal looks easy enough. Everything is low pressure so no real problems with the fuel pump and injector. It should run OK on kero or lamp oil which is cleaner. I would look for an engine that appealed and then draw it up with what ever process you have e.g. CAD or pencil and paper. There are plenty of four cycle hit and miss engine plans out there so just grab one of those and use it to get the basics right. I wouldn't have a cylinder bore of more than 1 inch. The hot bulb, I would make out of cast iron round and the injector can be brass. You only need to spray a very small amount of fuel into the hot bulb so the fuel pump will be of the jerk type which is quite simple to make. To control the speed, you can use a sliding wedge between the pump piston and the cam. The cam will need to have a reasonably sharp lobe to provide a short sharp injection. The injector can be of the popit valve type or needle
valve type. Have a good look at some of the photos of Fine Hanson's engines as he has done quite well in this regard.
Hope this helps
Bruce
I don't know if that lister ever ran as a true diesel. I think George the designer only had it running as a compression diesel like a model aircraft engine not pumped.
The ones linked to on the Alyn site are also hot tube ignition not hot bulb.
A start for glow head engines interest can as well be SAE paper 2002 -01-0115 Olaf Erlandsen, Lund University ,Sweden.
The term Semi-Diesel is nonsense.
Invented by marketing.
The Exhaust smells completely different to a diesel engine.
I got paper as pdf 260kb document from mr Erlandsen 2004.
Copyrigth expert anyone?
Find Hansen make and sell his creations and make a nice living.
They are not cheap.
Tuxham glowhead engine
Hundested
Hello, I have an idea for a two stroke hot bulb engine based on a youtube video of a swedish hot bulb engine,I would be willing to sell the drawings, just wondering how much would a builder be willing to pay? the lathe I have is not good enough to make some parts to I would have to out source the mafacture of some parts , so wondering how much would a person would be willing to pay for plans, I dont want to set a price too high I would build a working engine before making the drawings available , this could be a long time away as I an cuttently working on a model steam boat that I would like to finish first Ihave been working on it for over 14 years now.why so long you may ask, after starting to build, my twin girls were born , then I moved to Abu Dhabi where I was diagnosed with a brain tumor which lead to me having a stroke 8 years agoSo if I knew if builders would be interested in my plans and how much theymight be willing to pay I would make producing the plans and building the engine a priorty
Regards Gerard Beattie
Ireland
