Homemade measuring tool inner diameter
tornitore45 !
When I need to measure the bore diameter, I put the tool into the bore and I adjust the bolt 1, the number 2 will come out and come in contact with the cylinder wall, then I take it out and measure it again with my caliper
Interesting concept !
The reason that I went with three balls is the self centering. Two certainly makes construction simpler.
Agreed - - - - construction MUCH simpler.
Except with only 2 balls you're right back at the 'feel' problem.
It is so very very easy to be a small distance off of the 'exact' centerline.
That distance will result in a dia measurement error.
Generally not a problem if you're only working to +/- 0.002" (0.05mm) but if you're doing things like cylinder bores or even more so on injection pump bores
you rather should be working to tighter tolerance - - - just imo though.
So how do you measure the diameter with three contact points? You said with a caliper but a caliper will not measure over three points.
If that question was for me - - - well - - - you just don't measure using a caliper.
At this level its micrometers only.
It is possible to measure but you need to measure more than just one measurement AND use some trigonometry so its not for everyone.
