- Feb 3, 2013
- 88
- 47
Looks like I found it but it's in metric (scratching head) will it be precise enough if I convert it to inches? http://www.homemodelenginemachinist.com/showthread.php?t=23303
Just curious, the cam came out with lines where each cut was made, does anyone have a idea of what the boring head tool should look like? (The shape of the cutting tool, rounded tip maybe) And maybe what speed to run it at? (For the stress proof metal) if not I'll do more research and see if I can't find it. The surface was not very smooth per say.....
Yep M10x1 is a common size. I've used them in rc plane enginesOrdered .342 reamer
The spark plug is M10x1.0 is this a common spark plug thread size? Before I tap it I'd like to be sure.....
Yes the M10 X 1 is the size for the NGK CM6 most gas RC aircraft engines or the NGK CMR7H plugs, the later one is for most Zenoah engines in the 26 and 30cc range.Ordered .342 reamer
