tattoomike68 said:
Now days CNC mills rarely do anything but climb mill unless they are cutting through flame cut hard skin like AR plate or T1.
Mike's statement is totally TRUE!
Climb cutting is the preferred method on a CNC machine.
Keep in mind that a CNC gets it's speed by taking lighter cuts at much quicker recovery times between
passes.
Climb milling with an end mill will result in a better finish with less tool wear.
It
does require a snug gib adjustment and
COMMAN SENCE!
If your milling machine gibs are sloppy and you start into a cut climb milling cut the end mill cutting
pressure will pull the table into the cut and things will get ugly very quickly.
If your machine can not be adjusted to accept those pressures PLEASE be intelligent enough to accept
that fact! Hand polishing a milled surface is far better than having to spend a bunch of money repairing
a machine, OR paying the deductable on your health insurance!
No finish or speed of machining can ever be worth the risk of getting hurt!!!!
This hobby is about making things to show off and be proud of.
I'd preferr to see picture of a hand with all the fingers attached and in working order holding those
finished engines, taken by the clear vision of two undamaged eyes...
This topic is of the new style industrial age.
At home things are much different!
Be
SAFE guys!!!!!!
Rick
