Hit me - Miss me?
Hi Bob,the valves can be swines at times. Not trying to tell my granny how to suck eggs but I find a valve seat cutter and very very fine diamond paste or smokers tooth powder to lap em in and only the slightest bright ring when they are done.
Good luck you will get there.
kind regards Frazer
Dave, Herbie, Jim, Dean and Frazer,
Thanks for the support and advise. :bow: :bow: :bow: :bow: :bow:
You have given me inspiration to move forward :)
Best Regards
Guys I'm sorry this is so excruciatingly slow and I must admit that I'm just a tad peeved at 2steps forward 1step back. That said, I refuse to let a couple of bits of steel get the upper hand so I will spend the rest of this week licking my wounds.
Living remote from the workshop can't help either. I'm hard pressed to force meself down the 12 steps to mine in this weather.
What? No flop setup in the corner? Shame on you mate!! ;D
BC1
Jim
Bob: Just finished reading the complete build log. What an education, thanks for posting your progress or sometimes lack of. Will be here till the fat lady sings. good luck. Roger
She's gargling at the moment - the full song will be along soon. I should hear the cheers from Bob from my place........
Cheers indeed! Then he needs to pack up that shipping container and move it behind his house! Every guy needs his man er ah cave!
;D
Yes indeed - absence doth not make the heart grow fonder, it maketh the hand grow idler!
tel, Jim, Roger, Gavin and Dave,
Thanks guys, :bow: :bow: :bow: :bow: :bow:
th_wav woohoo1
We have kick back compression :eek: :eek: :eek:
The toothpaste did the trick.
Best Regards
I hope you saved me a seat Bob :big:
Looking forward to it ;D
Pete
Bob----I used to get kick back compression from cooking my own dinners before I got married!!! ;D ;D I am looking foreward to seeing this beastie run.----Brian
Hi Bob
good to see you are making progress. Sparks, compression, fuel is all that you need to make it go bang. Then you have to get the cam and ignition timing correct and the correct air fuel ratio and it has to run.
You have done well considering the interruptions and distance between home and shop.
Barry G
Next time I loose compression, I just need to remember to brush my teeth!
Things are sounding good, Bob!
Bob,
Go get-em buddy......it won't be long now!
Hi Bob,
Just a little clarification if you don't mind, after ginding the valves with toothpaste do you rinse it off with Listerine or is that only indicated for use on Lister engines??? :big:
Keep at it mate
Terry
Guys, Guys, Guys,
:bow: :bow: :bow: :bow: :bow: :bow:
I still do when Galina serves Galupsi :p
Na, Galupsi is more effective. ;)
Terry
Following on from another thread, I rinsed with a large dollop of BGR. ::)
Best Regards
Now then fellas, if you want a finer grind on your valves, denture paste is best (it leaves no scratches ) serious ::) ;D
Graham Rof} Rof}
heh heh
Well, slap me sideways
I actually made some bits for the electrics today. Did I wire it up..................well my intentions were good but I had taken my electrical toolbox home for a little honey do sparking and so..................all my connectors and solder etc. were a mere 60km from me.
Ah well there's always next week..........back to the boiler
Best Regards
Hi Guys
Thanks for hanging in there guys.
We have IGNITION................I have also demonstrated my in depth knowledge of Holme's Law as the wiring clearly shows.
Best Regards
