Thanks for posting the video. Have you always used a Scotch Yoke pump drive? It's very compact. Are there any issues compared to a connecting rod drive?
Lohring Miller
That's some pitch you have there on the propeller. Never seen one as coarse as that before.
Paul.
Sadly John Benson has passed away he was co writer with AA Rayman of experimental flash steam.
He was still competing this year with his Son helping him.
His book gave me inspiration and was a Bible to me when I started building a flash steam hydroplane.
A link to his life with model hydroplanes.
**LINK**
Paul
Have you considered loading the prop by submerging it in a closed can of water? I believe Jim Bamford used this method in a simple brake dyno.
Lohring Miller
I obviously have a lot to learn, but that's what makes it fun. Could you explain what changes you made to your piston? I was considering a two piece aluminum with a cast iron top, but decided proven construction was a better place to start.
Lohring Miller
I'm rebuilding all my damaged steam generators that because of overheating and bursts made them too short for efficient steam production.
Now having a Tig Welder decided to try to reclaim them as the stainless tube is getting expensive.
The prove of the pudding will be when they are under competition conditions with heat and pressure.
Sorry some of pictures not that clear.
Paul,
Do you feel that a butt joined T.I.G. weld will hold at the high temp and pressure of competition speeds.
I could only find 6m lengths of St/St tube so to get the 32ft length of coil It was tig welded but I made a sleave about 1" long and had it T.I.G. welded at both ends with the tube inserted 1/2" from both ends and never had any trouble but then I was not running at the speeds you are, I have no knowledge of what my Temps and Pressures are.
Best wishes on your quest for speed.
George.
