Here"s what is needed for cnc
Tin Falcon
It seems like more folks are interested in CNC as time goes on.
so here is quick list of what is needed for a cnc hobby machine
1) a computer to run the thing usually fairly modest capabilities needed depending on software.
a second hand PC will usually do. Lots of choice out there. pc choice will depend on software choice.
so $0- $1000 for a computer.
2)Software cnc software to operate the system
a) Mach 3 cnc http://www.machsupport.com/ windows based commercial software well supported a good value.$175 license lifetime support the lifetime of mach that is.
b)Turbo CNC http://www.dakeng.com/turbo.html DOS based shareware $60 license
c)EMC2 http://linuxcnc.org/ linux based public domain software.
Notice 3 choices three operating systems.
$0 to 175 for control software
3)You may also want CAD Computer aided drawing software such as
http://www.alibre.com/products/
A basic home version of Alibre CAD is about $ 100 more for the pro and advanced versions.
and Computer aided manufacturing software such as http://www.cambam.co.uk/
Cam BAM is $150 for the license and there is a try before you buy.
4)you will need a motion controller for the motors the G540 in a nice package gecko $300 it is what I have.
G 540
5)you will need a power supply to run the motors IIRC about $50 but will vary depening on type and how much voltage and amperage you need.
6) motors . most hobby machines use steppers but servo motors are another option.
stepper motors $ 0 if you can scrounge $25 -$50 each to buy more if you go top shelf.
Lots of options here http://www.kelinginc.net/ and here [url]http://soigeneris.com/default.aspx
[/url] and here. http://www.imsrv.com/
And please read the threads in this section on my builds.
7) motion control hardware.
ball screw for mills here http://www.roton.com/Mating_Components.aspx?family=7059321
$11 per foot for the screws and $25 each for the nuts
You will also need some sort of anti backlash coupling and or timing pulleys to connect the motors to the machine.
http://www.mcmaster.com/#shaft-couplings/=7prg4b
IIRC paid $70 to $100 per machine for collars couplings etc w spare spiders.
8)Plans here http://www.stirlingsteele.com/Index.html and here http://www.fignoggle.com/and here is a guy who has done cnc conversion to the max lots more info here http://www.hossmachine.info/ IIRC $50 per set for plans. On my little lathe no plans just winged it.
9) other sources for components motors Power supplies couplers etc etc.
http://www.homeshopcnc.com/ more cnc components
http://www.hobbycnc.com/ value priced kits for those that want to keep cost down and build there own PCB controllers.
Hobby cnc shows control board kits for $65 complete packages for 3 axis kit under $ 300 this has everything but the machine ,couplers ,and the computer that is if I read everything right.
and yet more options options
http://campbelldesigns.net/
http://www.cnc4pc.com/Store/osc/
http://www.pmdx.com/
Gecko drive has a FAQ sheet that will answer many more questions you may have. like what size motor or power supply you need.
http://www.geckodrive.com/faq.html
Stepper motor basics by Geckco drive
http://www.geckodrive.com/gecko/images/cms_files/Step%20Motor%20Basics%20Guide.pdf
Control of Stepping Motors
A Tutorial
by Douglas W. Jones
THE UNIVERSITY OF IOWA Department of Computer Science
http://www.divms.uiowa.edu/~jones/step/
And here is a free tutorial to help you learn G-code http://www.betatechnical.com/autonc.htm
there is also a complimentary program to calculate speeds feed angles etc. Free
sorry folks link is now gone replaced with a commercial portal
There are also many fun to have add-ons such as pendants, DRO scales, limit switches ,spindle sensor, coolant pumps enclosures, tool changer qc tooling, the list goes on.
I personalty used an off the shelf X box 360 controller as a pendant the driver is available from the Mach 3 web site not problem to install and has custom configuration.
For those who want to run Mach 3 from a lap top computer you will likely need a smooth stepper board $155 -$165 http://www.warp9td.com/ a little more for the new Ethernet card.
Bottom line is the cost of a CNC conversion can vary greatly depending on your choices, your scrounging abilities your electronics abilities and your machining abilities and experience. Realistically anywhere from about $200 if you are really creative to $3000. if you go all out.
10)And last but certainly not least a machine to convert.
the x2, x3 taig and Sherline mills and the Taig ,Sherline and 7x lathes are popular choices.
Normal disclaimers. Some of the listed companies I have dealt with. Others I have not. I have not had any bad experience with any of them. No affiliation etc.
Are you confused yet. Anyway hope this helps folks get started in cnc but please learn manually first you will be glad you did.
There is lots more out there. Experienced folks please feel free to add to the list. and thank you to Ron Ginger, Brian of Artsoft the makers of mach 3 and all the folks that have helped me in my journey to cnc in the home. Do your home work there are lots of choices.
Here is a link to a site where they review the different non-commercial servo drives out there.
http://www.thecubestudio.com/ServoDriveReview.htm
I have personally used the Gecko servo drives and I would avoid them now that there are other, better, drives out that dont use the encoder hunt method or need a scope to tune them. The Whale3 seems to have pretty good reviews.
For spindle control boards , the modio board, and other goodies Homann Designs in Australia is great.
http://www.homanndesigns.com/
Edited: Wow, I just reread it and my post didnt make much sense. Fixed, I hope.
Thanks Tin, that's a very helpful list. I've always been CNC curious and I may convert the X2 eventually.
decided to put this in for a bit of humor on the subject
Ode to a cnc build
Oh for parts to be simple
my soul to be free
what I really need now
is to build a cnc
Motors are needed
to make the thing move
then I need software
to program the groove
Couplers and ball-screws
to prevent back-lash
otherwise my parts
may go in the trash
Pulleys and belts
A supply for power
the cost keep rising
it seems by the hour
I am doing this I say
to make parts with ease
is this really a Hobby
or a mental disease ?
progress moves on
completion not far
my money not spent
drinking in a bar.
happy I am
life could be worse
but instead of machining
here I write verse.
Tin Falcon
25 Feb 2010
For those of you who are experienced in electronics and want to build from scratch here is a valuable site.
Loads of info [url]http://pminmo.com/ [/url] I found this site while looking for info on wiring a g540 up to and X-2 for spindle control.
instructions and resources for building power supplies BOBs (Break Out Board) and motor drivers including instructions to hook up with mach 3.
One of the challenges of wiring stepper motors up to a cnc is how to deal with the connection to the motor. How does one make this neat professional looking and preferably coolant resistant. My first CNC build this was primitive at best. I simply but splice the wires to my cable and pulled clear plastic tubing over the wires and added the customary wire tie to hold in place.
The second attempt was a bit cleaner I used a small radio shack project box to contain the connection and attached a db 9 conector to the box and used latex sealant caulk to hod the box to the motor. Note to self and others remember to scuff th bottom of the box first. Well here is a better solution to this
http://www.cnc4pc.com/Store/osc/product_info.php?products_id=297
An actual motor end cap. this is probably about 5 times the cost of the project box but a neat solution .
$14.95 from cnc4pc
Circular DIN Connectors are perfect for motor connections. They are more expensive than Jones Plugs & Sockets but well worth the extra cost. Mouser has them. You can refine your search down from here.
http://www.mouser.com/Interconnects/Circular-Connectors/Circular-DIN-Connectors/_/N-76q5g/?
Jones Plugs & Sockets would work fine as long as you pack them with Marine waterproof grease. The grease will protect the plugs and sockets from coolants and cutting fluids. Pack it around the solder connections and coat the blades to prevent corrosion. It will work as a dielectric and it's the same stuff sold in automotive parts stores as bulb grease @ $2.99 for a tea spoon amount. You can buy a tub of Marine or Trailer waterproof grease for about $5. The grease is dyed green for colour coding.
http://www.mouser.com/Interconnects...wer-Connectors/Jones-Plugs-Sockets/_/N-7auw9/
This is the kind of grease you need.
Anyone using the HobbyCNC pro board? Electronics is my 2nd hobby so soldering it up would not be a problem.
I have a MiniMill that I have been debating what to do with. Not sure if I want to sell it or convert it to CNC. CNC would be nice to have for some things in the shop. I have a Clausing 8520 that I really love but want to keep it manual.
Dale
That was one of the options I considered when going to CNC the G 540 was just coming out then .
for some reason the DIY boards use the 5 wire, 6, 8 wire steppers . IIRC that was a down side for me.
Depends on what you are looking for. IMHO opto isolation and a charge pump are nice safety features.
I put together my CNC for less then $3000 a little over 2 years ago. Here is what I purchased to put it all together.
K2CNC 2414 basic machine with 7 inch Z axis.
Hobby CNC Pro board with their strongest NEMA 23 steppers
Mach3 for machine control
CamBam for Drawing and G-Code generation
ER25 collet set with 1/2 straight spindle
Bosch 3.5 HP Router for spindle
Assorted carbide end mills from ebay sales sites
Since putting the initial setup together, I have added a couple of smaller collet sets, a rotary table with 3 jaw chuck, a nice 4" machinist vice, a 3 X 4 Angle Plate, a pair of 123 Blocks, an analog Joy Stick for X & Y control, hold down clamp sets. In addition I purchased a Harbor Freight 7 X 10 lathe on sale for $299.95. Probably about $1000 spent in the past 2 years on the above additions.
George
Though not a requirement some folk, schools and labs use machinable wax to prove or test cnc programs . while letting the computer run though it paces and watching the tool path on screen or cutting air can be useful , machinable wax has some advantages. It is soft enough to give and distort should a crash occur it does not wear tooling like metal and it is hard enough to take and keep a machined shape. Supply houses that serve the jewelry industry is one source . MSC and enco stock some and lat but not least you can formulate your own and cast to any desired shape ( within the laws of physics and rules of casting)
http://igor.chudov.com/manuals/Homemade-Machinable-Wax.pdf
hmm the gecko site still shows $299 for the G540. the 251x which is the daughter board driver that the 540 is based on more or less( the 540 actually uses 4 G250s ) has increased in price IIRC they were IIRC $55 each now $69
that price you mention may include mark up and VAT.
Kieling.com IIRC in Chicago has the G540 for $249
most probably is, with import duties as im in the UK. i will do a bit of googling. no doubt I can source one for the price you have found in the states
yeah you should be able to get one for close to half what you mentioned. I have no complaints with my chinese motors but if I was doing another mill I would go for the gecko motors as well IIRC les than $10 per motor more for made in usa. There motors are $59 each $55 each if you buy 4
tin
Tim Do you get the solfware when you buy a small cnc mill . Thanks Dale
All the CNC sofware I mentioned earlier in this thread is available on line as a download . http://linuxcnc.org/
EMC2 is free open source software that run on linix http://www.ubuntu.com/
Turbo CNC is Dos based software available here http://www.dakeng.com/turbo.html
The download is fully functional and you are encouraged to try before you buy if you use it and like send in the $60 for the license.
Mach 3 is windows based. http://www.machsupport.com/ again you are encouraged to download the program and test it before purchasing the license. the license is $175 for Mach and $ 50 for the mill add ons the mill add ons is conversational programming. the program has you make choices and fill in the blanks it then generates G code based on your input.
To answer you question it will depend on the mill and the vendor. any plug and play mill package will have to be set up with some software the question is does the price of the mill include a user license.
Sherline ships with EMC2 so no worries IIRC the mills from Littlemachineshop .com come with a mach 3 license. the mill add on would likely be optional. other vender check there web sites.
Thanks Tim You are so kind .Me and coumpter do not get along well so it would be great to be able to try them frist .Thanks again Dale
