Hello folks,
As a relative newbie I’ve been working on the Tiny frame and was just putting the finishing touches on the crank retainer. The plans show a .086 diameter hole for the thread portion and .146 dia for the screw head relief. Unfortunately, I drilled the .086 hole all the way through into the body and of course that hole is now too big for a 2-56 thread.
Is there some conventional way to fix this? I could turn some aluminum down to .086 and loctite it in. Or do the same with some brass tubing that is close in size.
Any comments would be appreciated.
Thanks, Harry
Thanks, Harry
