Captain777
- Feb 23, 2013
- 13
- 1
Hi,
I just made an eccentric from a 3/4" brass rod, 5/8" size of the eccentric and the hole (1/2 the valve travel) offset .155" for an eccentric movement of .310" .
I used the 4 jaw with the brass rod centered to within .001" with no problem. However, when I did the offset for the axle hole, I used my dial indicator on the cut part of the eccentric and used it to get a total indicator travel of .310".
This took me 45 minutes to do this. I had just set up the initial cut in only 3-4 minutes. (I seldom do 4 jaw centering, but I understand the mechanics behind 4 jaw centering.)
Should I have done the offset this way? Is there a "trick" to moving the part for the offset? How much do you loosen the other 2 jaws that are "not" to be moved for the offset? I wonder if I loosened the "off side" jaws too much or not enough. It seemed as if I would get close to my measurement, and then the turn of the chuck would show being off 20-30 thou.??? Would I have been smarter to just use the outside of the 3/4" brass rod and move it .155"? Does it make a difference if you place the dial indicator vertical or horizontal? For a round chuck, it shouldn't make a difference?
So many questions for what should have been a simple operation.
In the end, my hole was drilled and reamed where I wanted it, but for my next eccentric, I sure would like to do it a little faster.
Thanks,
Dan Fuller
Carrollton, Texas
Thanks,
Dan Fuller
Carrollton, Texas
