I am building Elmers twin wobbler and so far all is going well except for drilling the exhaust port in the column which is 1.6mm i have to drill all the way through by drilling from both sides and meeting in the middle. I started drilling from the first side with plenty of WD40 and guess what 'Snap' so i thought drill from the other side then knock the broken drill out . So i started drilling from the opposite side guess what 'Snap' :'( . I have now remade the column and not wanting to make the same mistake again i thought i might seek some advice. I am using a pillar drill as i don't have a mill the work was in a drilling vice and clamped down so as not to move . Could it be the speed i am drilling ? my drill has five speed options 600 rpm 900, 1250, 1750, 2500rpm i was using the 600 rpm choice as that looked fast enough but i am often wrong.
Any advice would be appreciated
Rob
Rob
