drysdam
- Feb 10, 2012
- 87
- 7
I just looked at what I think was a really nice a SB 9". It's been sitting in a garage for 15-20 years and was apparently lightly used by a professional (in his home) previous to that. ~1962 manufacture date, Model A. Built-in bench.
It isn't running right now because the power was apparently snipped off at the wall. We're going to try to get it powered to check it out. However, I went through the advice here: http://www.mermac.com/advicenew.html and it all looked good. No shaking or jiggling in anything, all the oil cups full, no ridge on the ways. I was able to run the barely-loosened carriage the full length of the ways. The 3 jaw chuck was a little surface-rusted, but otherwise it was in good (but greasy/oily) shape. The headstock came off with very little trouble. Both the tapers seemed clean and smooth. No missing gear teeth. Rotated the headstock with no trouble at all. The v-belt was worn and the detent (or whatever it is--the lever you grab to "take it out of gear") that tightens/loosens the headstock pulleys from the countershaft was missing, but I assume it was somewhere in the shop. Engaging the half-nut stopped the carriage cold, I otherwise wasn't able to check out the apron.
The problem is that neither the seller nor I know where to price it. I've looked on ebay and price for Model As varies from as low as $300 to as high as $3000. I found two closed auctions that look pretty close to what I saw:
Exhibit A: http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&hash=item4cfe65b95c&item=330685593948&nma=true&pt=LH_DefaultDomain_0&rt=nc&si=VbQRsxVghytoQtRmECO4Dk5hfP8%253D&orig_cvip=true&rt=nc
Exhibit B: http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.l2557&hash=item5648b71e65&item=370587147877&nma=true&pt=LH_DefaultDomain_0&rt=nc&si=VbQRsxVghytoQtRmECO4Dk5hfP8%253D&orig_cvip=true&rt=nc
I'm pretty sure that B is overpriced at $1500, especially as it comes with no tooling. But I'm also fairly sure that A was a good bargain at $800. The lathe I looked at comes with a significant amount of tooling, including many cutters, a few collets, a couple turrets (in addition to the original lantern), a few dogs, a drill chuck or two, some misc stuff that I can't remember AND what looks like a pristine, Craftsman, 8" 4 jaw chuck new in its original box.
In order to move it, I'm probably going to have to rent a truck and even then will need to remove the lathe from the bench to get it down the stairs into my basement.
I'd really like the value of this to be ~800-1000 but in my heart I fear it's more like $1500. Actually, in my heart of hearts, I truly fear a fair price is more like $3000. What do people here think?
