I have a Harrison 190 that I am just starting up. The main contactor was burned up when I got it. I replace it with the same contactor that was there before. The contactor is normally open. The contactor is energized at all times and of course hums a little. Im new to motor controls and electrical work of this kind so I am questioning if the lathe has somethinig wired wrong. I can see that at one time there was a contactor with a different foot print. I also see now that I think that the contactor is too small as it is labeled as 3 HP at 230 volts. My machine has a two speed rated at 3HP and 7.5 HP. It is rated at 25 amps and the motor full load amps is 21.6, so I am not understanding that variation either. Isnt it unusual for a machine to sit there and use electricity around the clock if it isnt being used? The only way to make it stop is to turn off the main disconnect. I have not been able to locate a schematic so if anyone has one to share I would greatly appreciate it. I have been able to find manuals but no schematics.
Thanks
Thanks
