Sorry for no reaction on the flange question Kludge, nothing wrong with them providing the mating faces don't resemble a plowed field, or better still they do but with a suitable gasket material between them. Have also seen flared ends on pipes of model steam fittings, like car brake pipe ends, the instructions for the HSB state this on the leader to the heater coil. You could use straight tubes for the water tubes, but what the designer has done it to try to get as much heat extraction from the blowlamp flame - Flash steam boilers are coiled tube - normally, if you can call flash steam normal.
Just a thought John and Marv. If you both set small bank accounts on opposite sides of the pond, you could send each other "" Presents "" An oppo of mine in a "Far eastern" country does this. A matter of mutual trust, but Hey, can't see a problem with you two, OH buns, ANYBODY on this site, although SOMEONES reference to Yorkshiremen has created an entry "In Zee Book" (Think his name begins with D )
You learn something new every day, never heard of the taper taps and dies for ME sizes before, seems a contradiction in our sizes for the problem of locking a taper. Seen the NPTF threads in proper engineering, but they can be machine cut, just never come across them in our sizes.
Regards Ian.
