- Mar 3, 2008
- 243
- 20
I needed a "shop Boiler" to power my steam models. I found these plans on this site and I started to build it a few weeks ago. Most of the parts I got from local hardware stores. I only had to "fire-up" the lathe to make the Safety valve. Today I gave it a test, only pressurized it to 5 Psi, appears to work OK, I will do some more tests next week.
Before I put the heat to it, I did a Hydraulic Test to 80Psi. I only intend it to run it at 15 - 20 Psi. Next I hooked it up to the air line and set the safety valve to 15Psi
Here is the setup I used:
I still have to make a base for it and also a bracket for the steam pipe valve.
Here is a video of the test, sorry no sound:
Overall it was a fun project and the hardest part was finding all the fittings.
IRONHOURSE
IRONHOURSE
