- Jul 8, 2009
- 775
- 252
If anybody else has purchased a set of these and been less than impressed with them, I got a couple of tips that might change that.
First, check the relief angles on the tool holder. Three of the 5 tool holders in my set were contacting the part before the cutting edge was. A few seconds at the belt grinder fixed that. Then a couple of swipes with the cold blue and they're better than factory.
Second, and most importantly, change the crappy inserts that they come with. Mine came with absolutely no information regarding what insert could be used for replacements, apparently you are supposed buy a new set when you run out of cutting edges? It took me a while but I finally determined that they came with a TCMT09 molded insert. Molded carbide inserts do not have a sharp cutting edge, itty-bitty lathes like my Unimat and Sherline need SHARP cutting edges. I changed the inserts to TCGT09 inserts, they are designed for cutting aluminum and have ground cutting edges. I had heard from others that they were using ground "aluminum" inserts on steel with good results.
So, I ordered some on Ebay. Since they were only about a buck an insert it wouldn't hurt the piggy-bank too much if things didn't work out. I'm very happy with the results. I may have to go back to HF and get a second set so I can have one set for each lathe.
Don
Don
