Kpar
Kpar
Anybody know where I could get some Hi453166 Hall sensors as indicated below ?.
Are you sure that is the right part number? Nothing to find under that number in Google besides your own post. (suspicious). The number should at least produce a data sheet.Anybody know where I could get some Hi453166 Hall sensors as indicated below ?.
timo, I took a photo & enlarged it the number on the sensor is "Hi453166"Are you sure that is the right part number? Nothing to find under that number in Google besides your own post. (suspicious). The number should at least produce a data sheet.
Can you find out what it does? Or know what it is supposed to do? The table below I copied from a datasheet, link below.timo, I took a photo & enlarged it the number on the sensor is "Hi453166"
Just tried an "AN503" from Jaycar, no response from magnet.
I found that the Chinnese Blue hit & Miss engine shows this sensor but unable to find a supplier.
Kpar
Probably this is the way.Digikey. I have used the Honeywell 400 series before.
Thanks guys, I'm not very savvy with electronics so will try a honeywell 400Probably this is the way.
Couple of hundred sites on Aliexpress alone would have to disagree with you..................................The Allegro A3144 is discontinued.
Other 3144 labeled parts cost 0.05 USD (50Ct for 10 pcs) plus 2.5 USD shipping on aliexpress.
View attachment 163667greetings
Disagree with what? I do not get it.Couple of hundred sites on Aliexpress alone would have to disagree with you..................................
https://www.aliexpress.com/w/wholesale-ky%25252d003-hall-effect.html
