Tin Falcon
- Jul 9, 2007
- 7,207
- 789
Sears has the tiger 2500 model as well for $208 bigger wheel 10" and 3 times the power. 1/4 hp motor as apposed to the 1/12 hp.
we do not want to get it that hot. like others have said hold in your bear hand when it start to get warm cool the tool.
Gus I believe Lenard is using one of these he will have to tell you the model.
the Japaneses water stones are dear at $250 each but with care should out last the operator.
IMHO Sharpening supplies.com offer good value and ships fast htis is the place I purchased my Norton white stones.
Tormek Sharpenter
This one pictured is about $380 plus shipping.
Grind bare handed and you will have no trouble with overheated HSS as it will require dipping in water regularly just to hold the stuff.
Gus, Im in Oz. Retailers are Hare & Forbes, Total Tools or CarbaTec.
Mine is a Tormek but there are others available. It will sharpen everything from a pin to an axe & various jigs are available. Would make an interesting shop exercise making the jigs. I have had mine for over 30 years - purchased before I got into hobby metal machining, & in that time I am on to my third stone [ used commercially ] so not a cost consideration. I would reccomend them to anyone. Not cheap but my favourite tool & has saved a lot of anxt over the years. I always know my edge tools are sharp, & that makes fo easy working.
That's easily solved Gus, get a bigger shed so you'll have room for that grinder you're dreaming of.
