- Dec 28, 2008
- 548
- 4
Problem: Position and drill tiny holes. (#79 and #80 size)
Solution: A Morse Taper #3 holder for a Dremel Flex Shaft running through the Mini Mill spindle.
Execution: Machined the holder on the money. Nice tight fit in the spindle. The Dremel Flex Shaft fits tight in the holder. Locks in nicely with a set screw. Mount up the Dremel Drill chuck. Insert a #79 bit. Now I have a nice high speed drill that I can accurately postion. Wrong!! The Flex Shaft has run out. So much, that I could use the end of the drill to tram the mill!
If I had only thought to check the Flex Shaft for runout before I made the holder. oh:
