rklopp
- Oct 6, 2008
- 401
- 115
I am building 3 Nanos. I ran into an inconsistency in the dimensions providing
the angular location of the inlet port relative to top dead center (TDC). The
text and drawings ask me to lock the crank at 43 degrees before TDC and drill
the port through the venturi. The drawings say to get the 43 degrees by setting
the crankpin 0.8 mm below its height at TDC. If you work out the trig,
considering the 2.5-mm crank throw, 0.8 mm BTDC puts the port at 47.2 degrees
BTDC, because ArcCos((2.5-0.8)/2.5)=47.2. If the position is really supposed to
be 43 degrees, the distance below TDC should be 0.67 mm.
I built the cranks with the port at 43 degrees. The port begins to open at 112
degrees BTDC and fully closes at 26 degrees ATDC. I sure hope this is correct.
Has anyone else run into this issue?
