Gibb Adjustment
rake60
We had a problem with one of our production turret lathes at work today.
The snap ring groove in the parts checks out to be in the middle of the tolerance using
a dial caliper but it will not go through the the GO side of a Go/No Go gage.
Looking at through an eye loupe or on the comparator shows clearly that the bottom of the groove
has a sever taper on it.
The groove is very narrow so the calipers are just measuring the middle.
It measures right, but it isn't right.
I tried several things to adjust it to cut straight but it was moving all over the place.
Then I unbolted the hydraulic cylinder from the cross slide to to check the gibb adjustment.
[ame]http://www.youtube.com/watch?v=mlMW4TBJ5yw[/ame]
(I just happened to have a micro video camera in my pocket.)
Well there certainly isn't too much drag there! ::)
After adjusting that slop out of the gibb it cut square and fits through the idiot gages.
Then I went on to adjust all of the gibbs on those machines.
They were all that bad or worse.
Have you checked your gibbs lately?
Rick
While waiting for a replacement centrifugal motor start switch for my lathe I did go over it cleaning and adjusting everything including the Gibbs. Only a very slight adjustment was required on the cross slid Gibb.
I doubt these had been checked in the past decade.
When the hydraulic cylinders are attached there is always pressure either in or
out on the slides.
I didn't realize just how bad they were until the cylinder rods were unbolted.
Rick
