100model
A while ago I disassembled a industrial sewing machine for cast iron melting so as a bonus there were some small gears that could be useful for making model ICE engines. Al these gears were made in steel except one.
These are right angle drive gears that could be used for a side shaft ICE engine. They are 2:1 ratio and the large gear is 43 mm dia. small gear is 22 mm dia. 30 X 15 teeth
I found another one but left the gears in the original housing so I know the distance between shaft centers.
One of those two industrial sewing machines right angle bevel gear that are 2:1 ratio as well. I am not sure which gears had SIMANCO stamped on them which could be singer sewing machines.
In my never ending quest for scrap cast iron an izuzu engine was dismantled and found the distributer drive had the same gears as the first two photos but the driver gear is larger than the driven gear. These are too big for models but one of these days I will make a full size side shaft hit and miss engine.
So I dismantled a modern sewing machine and found that that the driven gear is made out of plastic so if you think that is a bad idea have look at the next photo. Plastic gear is 27 mm dia. and the small gear is 12 mm dia, cams and gears are all made from plastic
