- Jul 1, 2012
- 475
- 412
Guys please explain me this:
I would like to start to cut my own gears so i have decided to buy
gear cutter from Ebay .
One vendor description is:
HSS Tool Steel
Precision Ground Form Relieved Cutting Teeth
Pressure Angle 20 Degr.
Bore with Keyway
Module 1
A different Cutter is required for each Gear:
Cutter #1 will cut a Gear with 12 to 13 Teeth
Cutter #2 will cut a Gear with 14 to 16 Teeth
Cutter #3 will cut a Gear with 17 to 20 Teeth
I absolutely do not understand why i can not
use cutter 1 for cutting gear with / say / 84 teeth
or why is required different cutter for each gear.
Thank you a lot
HSS Tool Steel
Bore with Keyway
Module 1
Thank you a lot
