- Jun 24, 2010
- 2,425
- 959
Im working on my single cylinder 4-stroke design. Its kind of a starter / proving project that hopefully will grow into a 5-cyl radial ..one day. But first things first.
The layout shows 15-tooth DP40 drive gear engaging a (2:1) 30-tooth cam gear. The challenge (moreso on the radial) has been packaging this cluster into a compact, constrained volume. If I select a larger DP (for bigger stronger teeth) or add more teeth, the gear cluster grows & I run out of room. I could go one size down to a DP 48, the drive gear starts to get pretty teeny. Anyway, this is what I have so far. Interested in your comments on practicality or potential problems.
For the drive gear, I figured I would pre-install it on the rear crankshaft segment outside the engine. It doesnt really matter what clock position the gear is its in from what I can tell, but it would be a lot easier to do with the crankshaft outside the engine. To retain it, it I assumed a cross hole through the hub & into the CS. I have seem RC model pinion gears that have a set screw that ingages a flat or countersink on the CS. Maybe thats better?
The cam gear requires a different treatment. he camshaft needs to be clocked into position once the crankshaft is in, so is dependant on however the drive gear is positioned. I show 2 pre-drilled pilot holes through the cam gear. Im envisioning, locktite on the camshaft, clock camshaft in position, loktite sets, carefully remove 'fixed' assembly, drill through pilot (guide) holes into the camshaft body, install permanent pins with locktite. (In the case of radial, this would have to be repeated for each cylinder).
What do you think?
What do you think?
