What will be the outcome if I use a .8 module cutters instead of a .5 module cutters it calls for? Will my shaft center distance be off? the gears are the crankshaft and cam. a 36 and 72 teeth
You can preserve shaft distance with different modules by adjusting the number of teeth.
pitch diameter is N x M, so PD =36 x .5 = 18
some modules that will have PDs of 18 with an even number of teeth are
PD = 45 x .4 = 18 PD = 90 x .4 = 36
PD = 36 x .5 = 18 PD = 72 x .4 Shaft distances remain = (18 + 36)/2 = 27 (but OD = (N+2)M)
PD = 30 x .6 = 18 PS = 60 x .6
PD = 20 x .9 = 18 PD = 40 x .9
PD = 18 x 1 = 18 PD = 36 x 1
So you can us some modules other than .5 for the same shaft distance.
You could consider .8M gears
20 x .8 = 16 (16+32)/2 = 24
25 x .8 = 20 (20+40)/2 = 30
30 x .8 = 24 (24+48)/2 = 36
35 x .8 = 28 (28+56)/2 = 42
.8M gears of 25/50 with 30mm shaft separation would probably work for a low RPM engine.
