simister
Hi,
I am about to start building the Kerzel Hit & Miss. However, I wanted to practice cutting some gears.
I purchased the indexing plates for my rotary table and set it up on the mill.
I have had 3 attempts and can't quite get it correct.
I am trying to replicate the small tooth gear on the Webster Engine for practice.
This is my set- up
24 teeth
0.8 module Number 4 cutter.
Cutting depth 1.8 mm
20 hole index plate - 3 full turns plus 15 holes.
I am getting 24 teeth and 23 of them look good, however, the last tooth is too wide. I am not sure what I am doing wrong.
Any help on this would be appreciated as I am very new to gear cutting.
I have attached a photo.
Regards, John
This is my set- up
24 teeth
Regards, John
