Gear Cutters
kiwi2
Hi all,
I need to cut a gear which rotates eccentrically inside a ring gear. The gears are shown in the pictures.
The gears are module 0.3 with the ring gear having 119 teeth and the inside gear 107 teeth.
My question is - Should I use an involute gear cutter to cut a new inside gear?
Alan C.
Thanks Dave. The teeth are so small it would be difficult to see if their profiles matched a gauge. I guess what I need to know is whether a gear which meshes with a 119 tooth ring gear has the same tooth form as one which meshes with a 119 tooth external gear.
Alan C.
I'm different. In another world and in another appication, I might agree about mini sized modules and wishing that I'd not scrapped my old shaper. Not here. It looks -to me- like a nylon moulding and it will cost more to mend it than replace the whole item.
So one could probably mend it- with a small soldering iron.
Goldstar, I don't think Alan want's to mend it, I believe he wishes to replace it, hence the question whether an involute cutter would have the correct profile.
Alan, I briefly researched cutting internal gears (like your ring gear) for a project that ultimately got shelved.
From what I could find(and I could very well have it wrong!) the inside spur gear has a 'normal' involute profile. It is the internal gear profile that is made to suit the spur (with undercuts etc). I could never find how to make a single point cutter with the correct profile for cutting the internal gear, hence the project's shelving. One day I will return to it.
As your internal gear is fine and you only need to replace the spur gear, if you are 100% certain it is a MOD 0.3 gear set, you should have no issue mating a new spur to the internal.
Besides, if you cut a Nylon or preferably Acetal(Delrin) gear, you could test it for fit and feel and it would be very unlikely to damage the brass internal gear one bit.
Point or some of it, taken but once one gets to' over 100' teeth, the cutter is virtually one for rack! However, as it is soft material, - and so small, who is really bothered?
However, Simon, You CAN cut a reasonably accurate set of gears with one tool- with rack or truncated forms. You simply grind a piece of tool steel- at each end. I recall Cleeve- he's the guy that did the screwcutting gubbins being tossed about here by doing a transposing gear of 127 which should have been 20DP but it would have fouled his lathe tray.
The trick is to use a magnifying glass where some of the greats show something else- and forget to explain the surrounding circumstances.
My wife once bought a house- using my watchmaker's loup on the advert.
I now use a pair of surgeons binoculars- because she wore the loup hinges out.
One reason why I cannot be arsed to take photographs- I watch too many things!
Thanks Simon - that's what I wanted to know. The gears are the fine focus adjustment on a Nikon microscope from the 1970s. Spare parts aren't available for it any more so I either need to repair the broken gear or make a new one. The existing plastic gear was moulded onto a diamond knurled brass ring fixed to the outside of the ball race. I'm not sure I can get it seated properly into the diamond knurling but I'll try.
If I can't I'll have a go at aralditing a piece of phosphor bronze onto the brass ring and cut a new gear.
Thanks for the comment Goldstar. I was tempted to use a flycutter to cut the gear but I can get a proper cutter from CTC tools for about $10 plus shipping.
Thanks all,
Alan C.
There is a case to make a new ring out of dental acryllic which is jokingly a way to fixing teeth. I recall my first decent drill had a guard made from it. So I married a dentist:)
