Gear calculation help please
chucketn
Senior Citizen
Near Jonesborough, TN
I am making a custom fine feed banjo for my 7x14 lathe. Ihave 20 and 80 tooth gears, from a laser printer, that are the same mod as the7x change gears that I want to use.
Is there a formula to calculate the center to centerdistance of meshed spur gears? I would like to lay out the holes for the gear axelswithout having to allow for adjustment for tooth mesh, making the attachment ofthe banjo via a clamp on the lead screw bushing.
Chuck
Those table sare best suited to DP gears
IN your case PCD = Number of teeth x MOD
so to get ctrs add the two PCDs and divide by 2
I figured that out, Jason. I converted Mod to DP and went from there. I'm a imperial type and have to convert from metric to figure things out.
Chuck
