Hi fabinho,
Here are the schematics for the arduino board and for the RPM sensor.
The arduino board
The RPM Sensor board
I'm not sure if the max6675 module is still available, but this is a replacement http://www.adafruit.com/products/269
The arduino code...
Code://-------------------------------------------------------------- // // Interrupt driven sketch to measure RPM, and Temps // it expects a suitable signal on pin digital 2 / external int0 // Display is via LCD. // //-------------------------------------------------------------- #include <LiquidCrystal.h> #include <max6675.h> #include <Wire.h> int thermoDO = 3; int thermoCS = 4; int thermoCLK = 7; MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO); LiquidCrystal lcd(13, 12, 11, 10, 9, 8); uint8_t degree[8] = {140,146,146,140,128,128,128,128}; int pwmPin5 = 5; // 976hz signal on pin 5, connected to a mosfet to drive a glowplug. int dutycycle = 80; // 25 = 10% duty cycle volatile word rpmcount; unsigned long rpm; unsigned long timeold; void setup() { pinMode(pwmPin5, OUTPUT); analogWrite(pwmPin5, dutycycle); //turn on the glowplug output. lcd.begin(20,4); // Setup the LCD, use 16,2 for a 16x2 LCD, etc. lcd.clear(); // start with a blank screen lcd.createChar(0, degree); attachInterrupt(0, rpm_fun, RISING); //enable int0 rpmcount = 0; rpm = 0; timeold = 0; delay(500); } void loop() { lcd.setCursor(0,0); lcd.print("RPM: "); lcd.setCursor(0, 2); lcd.print("EGT:"); lcd.setCursor(5,2); lcd.print(thermocouple.readCelsius()); lcd.write((byte)0); lcd.print("C "); if (rpmcount >= 100) { //Update RPM every 100 counts, increase this for better RPM resolution, //decrease for faster update rpm = 1000000*60/(micros() - timeold)*rpmcount; //rpm = (micros() - timeold); timeold = micros(); rpmcount = 0; lcd.setCursor(5,0); lcd.print(" "); lcd.setCursor(5,0); lcd.print(rpm); } delay (500); } void rpm_fun() { rpmcount++; //Each rotation, this interrupt function is run } //-----------------------------------------------
If there are any questions, let me know
Steve.
Good afternoon Steve, I made here a circuit as shown in your drawing to the glow plug more when I turn on the 12v Battery candle call and is still making connected do you have any idea what it could be?
