A couple of observations, I have the Busy Bee Tool's 'Craftex' brand of the same mill.
First, getting it down stairs should be quite easy. Since it is new, you will want to strip it down for a thorough cleaning anyway, so, remove the head and table from the base and clean\move, move\clean, reassemble, adjust, tram and go!
Second, depending how tall you are, re purpose the 'stock' stand for a grinder or something, and depending on budget, look at making your own or like I did, (scroll to bottom, right)
http://www.graytools.com/toolcatalogue/?page=subcategory&name=Side%20Riders&itemNo=522&s_filter=&recPage=9&startRow=1&pageNum=1
As well, the 'stock' stand, has but one shelf, you will soon find yourself spending a lot of time digging tools out as they start getting stacked one on top of the other.
Some initial 'tuneups' would include cleaning up, lapping the existing Gib strips or make new.
Again, depending on skill sets and budget, as simple as replacing the existing x, y and z bearings to the spindle bearings as well. Then there is replacing the drive from gears to belt and pulley, after that there's all sorts of options, Digital Read Out, upping the motor HP, riser block perhaps, quality Ball Screw\Nuts, to complete CNC.
Have fun,
Chazz
Edited to fixed link - Arnold
