G0602 spindle problem
mays landing NJ.
I had no luck removing the bearing with heat. I took the spindle to a bearing supply and bought new bearings. I was told to cut the old bearing off . I used a Dremel tool and it took less than 1 minute . I was told to use the new outer races . Not sure how to remove them , maybe the Dremel tool.
Tomorrow I will take the spindle and bearings to a garage and ask if they can press the bearings on. I never thought to sand the spindle slightly . Hopefully the garage can press the bearings on.
