Hi
I did some testing to figure out if friction welding stainless steel valve stems
would be possible at home. First I tried to do this with some scrap materials on lathe but I could not get a good joints. Also the tailstock was not really up to the task. For the next try I bough some 4mm stainless steel rod. (not sure which alloy) I set up the pieces on a milling machine as shown in the picture.
[/URL][/IMG]
This proved to be a quit easy and quick method. It would take maybe 5 seconds to heat the joint to glowing orange, aligning was easy and the pressure needed to heat the material was not excessive, maybe something similar to used with 10-12mm twist drills on steel.
[/URL][/IMG]
It took three tries to get a good weld. At least I am not able to break the one shown in picture without tools. With every try I heated and pushed the pieces to each other a bit more.
I still need to do some more destructive testing to see if I can get the process to be repeatable and to figure out how much strain these welds will take.
Henri
Henri
