Hello Arild,
Foseco Sweden are based in Ed not far from the Norwegian border and they would probably give samples of Sodium Silicate. A common name for S.Sil. is Water Glass, pharmacies used to stock it. You could also try begging samples from a jobbing foundry.
I like S.Sil. systems for the low toxicity, low odour. I don't like it for its thermal breakdown that makes shakeout or knockout more difficult.
The following descriptions will ignore binder systems impractical for home use such as Hotbox, Shell Sand (Croning), amine gas with iso-cyanate oils or resin systems. My experience is commercial/ industrial and practices that would not occur there due to high labour content, may be employed at home, where time is less relevant and part of the fun. For non commercial hard sand practices, core and mould systems are interchangeable.
Sand:
Modern jobbing (means one off castings) core making or moulding practice needs clean, washed and dried silica sand free of alkaline traces (seashell fragments), or clay, both of which lower thermal refractory properties and may interfere with binder systems . River sand is best since it has rounded grains that give low surface area enabling less binder for any given strength. The temptation is to go for fine small grain sand for finer as cast surface finish but this can give low mould or core permeability and needs more of any binder so is harder to compact. A good compromise is an average "Grain Fineness Number" of between 45 and 60, this means an average grain size of between one forty fifth to one sixtieth of an inch, I don't know if this is expressed in mm in Europe.
Coarser sand will need a refractory coating to prevent metal penetrating core or mould, these may be aqueous suspensions of graphite for aluminium or iron castings ( I won't describe steel casting practice since melting steel at home is beyond most people), the coatings are applied with a paint brush and dried with a low flame. Even rubbing on dry graphite to a finished core or mould is better than bare sand. Traditional "greensand" moulding practice has carbon from coal dust and clay from bentonite so generally doesn't need coating, just high compaction or ramming as it's called in industry.
Binders:
1. Sodium Silicate.
Self Setting.
Using a catalyst that is a low or non toxic ester mixture such as, Glycerol or Ethylene Glycol tri/di acetate, sodium silicate may be cold set. The catalysts are available from foundry suppliers (Foseco trade name is Carset) or the chemical industry. Again ask for samples or go to a jobbing aluminium or iron foundry and plead for help. "Triacitin" is slow curing, "Diacitin" is fast setting, so for home use Triacitin is best with set times of say about 2hrs at 20 degrees centigrade. The sand is mixed in a Hobart or large food mixer with about 3.5% by weight of the correct sodium silicate for about 3 minutes (Sod. Sil varies in soda ash to silica ratio used in manufacture). The catalyst is then added at 15% based on silicate weight and mixed for a further 3 minutes. The sand mixture is then added to core box or mould pattern and well compacted, rammed with a stick, especially into corners. The mix will then set hard. Stripping the mould or core is best done before total rigidity after "rapping" (hitting the sides) of the corebox. The finished shape is then allowed to fully harden.
CO2 Gas Cured.
The silicate sand mix is rammed into the corebox, vented with a small diameter rod and CO2 gas from a cylinder passed through it with a small diameter tube inserted or with a top board, edges sealed with rubber strip. The gas needs to penetrate to all areas and vents in the corebox may be needed for some shapes.
Core boxes or patterns need smooth surfaces, correct taper (draft) and a release agent like talc (baby powder) or wax to enable stripping the core or mould half.
Having written a small essay I won't describe cold set resin systems but these are hard sand process with high strength and good thermal breakdown properties compared to Sodium Silicate.
Good luck in sourcing.
Rob
